7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy),
57
Mod | | | Forums66 Topics128,008 Posts1,055,285 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69986 12/13/2006 11:33 PM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | First I'd like to say how much I'm enjoying this site. Having driven my truck all last summer I had never had it over 60mph.The last weekend before parking for the winter,I drove it up to 65-70.There was a vibation.I'll list what work that was already done to it before I noticed it front clip is 72 Nova -all parts ok tires are new and balanced,wheels are not bent drive shaft has been balanced This vibration was not in the steering wheel it was in the seat.I think that indicates something in the back.Any ideas that I can look for would be great.Thanks, Boyd | | |
#69987 12/13/2006 11:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The driveshaft u-joint angles may be wrong from changing suspension. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69988 12/14/2006 12:12 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BC52,
The vibration in the seat sure would indicate something in the rear of the truck.
The rear tires would be the obvious first choice, and easy to troubleshoot...put them on the front.
My money is on the drive shaft. Many times the urge to go the 'homemade' route is too strong, and whoever built the truck had his friend with the big lathe do the work.
If you think this is what it might be, you can use a couple of large hose clamps and do a "okie" balance job on the drive shaft yourself.
I can explain the balancing deal if you think it might help..or maybe you know it already.
Stuart | | |
#69989 12/15/2006 12:49 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Sounds like drive shaft problem.Had 55 chevy pickup greesed by service station once.While raising truck it was to far forward on lift and when lift came up it hit on the drive shaft puting a very small demple in the shaft. Vibration would start at around 45MPH. Keep us posted. | | |
#69990 12/16/2006 3:37 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I spent a long time chasing down a slight vibration at 65 MPH. After exhausting all possibilites except new tires, I tried Dynabeads. Worked great! http://www.innovativebalancing.com/gallery1.htm | | |
#69991 03/12/2007 8:02 PM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Update,I took the rear wheeels back to the tire store,and told them the problem.They did it again, just got back from a freeway drive.NO VIBRATION  | | |
