6 members (3800GUY, cmayna, 52GMC35424JD, JW51, Rusty Rod, 1 invisible), 98 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#699688 11/30/2010 9:18 PM
Transmission, stock 3 speed, rebuilt, and adjusted. Took the truck out for the a first run and the transmission runs fine but at some point the shift becomes jammed when down shift at a stop, to the point I have to get out and move the 2/3 gear linkage to neutral whereupon I am able to shift it again. Later at some point it will jam again and I have to do the same. What is the problem, is it linkage adjustment, either under the hood or the column or something else? Thanks for your help
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
it's adjustment and likely slop caused by wear inside the shift box on the lower column - should open that up and clean it up, make sure the notches are not worn and the spring is sound - you prolly changed things a bit with the trans R&R - see here and the next few pics
also note that as it ages the setup is prone to that problem if you're sloppy going thru the H pattern, don't "cut the corners"
Bill covers it pretty well, here's another write up on it...
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
