7 members (Hotrod Lincoln, Dave1234, IHPWR, TUTS 59, Peggy M, Wayne67vert, 1 invisible), 72 guests, and 4 robots.
Topics128,206
Posts1,057,440
Members48,471
Well I drove my 1950 truck around the block smile and the oil pressure reads a little over 15psi @about 2000 (I'm guessing) at idle it's at about 3-5 psi is this normal?
I'm running a straight 30 for oil.
Should it flucuate that much?
I tried to search the forum and couldn't find anything.
Any help would be appreciated
Plane,
Yeah that sounds about right. When the oil is cold it will be higher than when it's hot and at idle. It looks a little scary when it's at temp and at idle.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
I have a 1946 chev big bolt with a 216 in it. The oil pressure on mine is 15 pounds when warm.
14-15lbs at speed and 6-7lbs at idle when warm. #20 or #30 oil is fine for your engine or a 10w-30 multigrade mineral or synthetic.
At 3-4lbs I would suspect worn main or cam bearings. You might get by for a while by adjusting the main bearings.
DG
Denny G
Sandwich, IL
In my Chevrolet literature, I have not been able to find a spec for oil pressure at idle. They do state however that the minimum at 2000 RPM would be 7 lbs. I believe that was for a passenger car.
1951 1 Ton Completed
