0 members (), 83 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
Y
Y Offline
I rebuilt the Carb, Got it running reliably, adjusted the valves, Bled the brakes, cleaned the grain bed and worked the hydraulic hoist, and Air'd up the tires. It is slow compared to my 3/4 ton when driving. I am sure I need to check the timing and the dwell and such, but that will happen tomorrow.
Great day! Felt good to drive the battleship around.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
That's a big list for one day !I have a 1952 4400 it's just about ready for driving also.
Good luck tomorrow you had a great first day.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Y
Y Offline
Running strong, Hoist Working
Notice the red and white Paint on the bed?
The White strips are removable by turning small brackets to give you a breathable stakeside. The bed will be cleaned and re-painted to match original, everything was paint top bottom, EVERYthing.
Not fully up, but close
The bed was not fully up here, but good enough for the time being. I will replace the hydraulic hoses and fluid. The seals are in good shape.
I took the bed extenders off. When cleaning the cab out I found some grain receipts from the Elevator in Adams NE. They showed where the Owner turned in over 15,000lbs of corn. The Serial plate shows 11,000lbs. Considering that there are over 30 receipts for loads over 15,000lbs the sludge in the gearbox is not a surprise. I will warm it up and drain, and clean out a few times. Overall everything is in good shape. The seat cover and under the seat had regular residents but Mickey's clubhouse has been cleaned out. More pics tomorrow with Videos.
Y
Y Offline
New wire harness and Rubber floor go in Saturday, as well as Timing and dwell adjustments, then a test ride.
I have a '49 4400 flat bed, too. Anyone have info on how to get faster road speed?
