1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi,
Doing some detailing and mechanical on my '54 3100 so it will hopefully make it from Orlando to the Daytona Turkey Rod Run this weekend ... if the weather is clear.
Three Questions: >> Question #1) What color was the bracket that holds the coil originally? Unpainted? Engine color? Some other color?
>> Question #2) The truck was converted to 12v by a previous owner. Has a Bosch 12v coil, but it was turned "wire side" up. I disconnected the wires and noted the locations so that I can turn it "wire side" down like the original.
The wire from the distributor was connected to the + terminal of the coil. I read on a Stovebolt post that it should be to the neg. terminal on the coil. The truck ran great before I disconnected the wires.
Did I record the connection wrong? I will replace the points, condenser, and rotor, so I won't know if it runs until I finish.
What will happen if the connections are reversed? Won't run, or sill it blow up in a thermonuclear armageddon?
>> Question #3) Should there be a ballast resistor somewhere in the system? I have't seen one.
Thanks as always for your help,
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | The truck ran great before I disconnected the wires.
I would reconnect like it was and drive it to the turkey run Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | If it ain't broke.Don't fix it:
dan-pa
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Lonnie,
Regarding your questions:
1. The bracket is/was unpainted, galvanized, I think.
2. The negative terminal goes to the distributor. If the coil primary connections are reversed, you will be firing the spark plugs with a positive voltage on the center electrodes, which will increase the firing voltage about 10%. You probably won't notice the reversed polarity until the spark plugs begin misfiring under full-throttle acceleration, after the gap increases with mileage. With the 6-volt system, you might also have some hard cold starts in cold weather- below zero temperatures. And, rest easy, your truck won't self-destruct, or blow you up, if you wire the coil incorrectly. 3. There should be a ballast resistor in series with the coil if the system was properly converted to 12 volts, but some 12v coils have internal ballast resistance. Measure the primary resistance of the coil: with internal ballast resistance you should find about 3 ohms, maybe a little more; without internal ballast resistance, the primary resistance should be around 1.5 ohms, plus couple of tenths is alright, but minus not much.
If you are back to 6-volts with the electrical system, you shouldn't have a ballast resistor, nor the coil with internal ballast resistance.
You can use the 12v coil if it does not have the internal resistor, but a 6v coil would be better. If the coil has internal ballast resistance, it should be marked on the case with something like "Internal Resistor", or something similar.
Hope this helps.
Harvester | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I turned my coil wire side up. It was easier to see the pointer on the flywheel. To each his own. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The reason that the coils were mounted upside down was that the old oil filled coils stayed cooler with the oil at the "business end" of the coil. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks for the help. > Harvester: I changed the coil primaries to be correct (neg to distributor) before I read your response. I found a few posts on some other forums that also said that it will work either way and agreed that it will loose a little firing voltage if reversed. The resistance across the primaries is about 3.4 ohms, so it looks like I have a coil with an internal resistor - great. The paint is slowly flaking off of my coil bracket, so it will soon be plain galvanized. > MarkT: I see your point that the high tension lead can obstruct the pointer. > Greg H: Thanks for the logic behind the positon. > joker: Even though it ran well before, I changed the connection, drove it to the Daytona Turkey Run, raised the flag, mounted an info poster, and proudly showed our truck - along with over 3,000 other cars and trucks. Here's my wife with our truck. Thanks again to all of you. - Lonnie
