2 members (Tstan7, Napco Mark),
75
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Dear Members: I want to put on Fenton Headers...I see there is a Fenton Manifold, but it is for dual carbs...Do I need dual carbs ? or can I get a single carb manifold and use stock carb.? and what about the pre fuel heater function ? How do I address that with the new/or old manifold ? I like dual exhaust, but don't really want the dual carbs.. Any help would be great. Thanks Jimmi V. 1954 Delux 3100 235 ci & 4 speed www.photobucket.com/snipe | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jimmi_V, It is not necessary to use a multiple carb manifold with Fenton headers, there is an exhaust to intake manifold heat kit available which plumbs two tubes, one from each header to a plate mounted to the bottom of the intake manifold where the stock exhaust manifold mounted, hope that helps. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Do we know who makes that manifold ? or the heater plate ? Thanks for the info. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Hi Jimmi, a member here sells the Fenton exhaust headers. Check out "CLETIS". I think the heat plate is seperate thru Langdons,or maybe Jim Carter. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jimmi_V, Jim Carter sells the kits, for Chevrolet 235 and 261 engines it is their p/n HPM543, for the Chevrolet 216, and the GMC engines 228 - 302 their p/n HPM544, I won't list prices cuz my catalog is a few years old, hope that helps. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can use your stock intake manifold. As pointed out above, Carter sells a kit for exhaust heat. Langdon sells one for water heat.
Carter's kit was $60 when I ordered one last week. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevs of the 40s now has a kit with one tube - lower-priced and probably adequate for heating the intake.
I am using Jim Carter's kit with two tubes to the Fenton headers. Works fine, simple plumbing, and no worry about coolant-line leaks.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Tim: Do you still use the stock manifold ? and this kit is to be located under the manifold and is heated by the exhaust manifold lines that go into it..... Also, did you have a set of exhaust pipes made at a muffler shop or use a pre-made bolt on type. And if you had them made did you have to trailer the truck to the shop ? or drive with headers ? Thanks | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | You still use your stock intake mani. When you remove the whole assembly from your truck,you'll see where they unbolt from eachother.Youll also see where the heat plate bolts back on your intake. I drove mine to the muff shop with open headers,,about 8 miles, i figured if i got stopped,it would be obvious to the cop where i was going. Small town,one exhaust shop. Good Luck, | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you have a good muffler shop in your area, do what Marty suggests. I live in a small city area and cannot find anyone who can/will make a useful exhaust system for my trucks (even shops that work on race cars). I ended up buying a beautifully made polished stainless system from Patrick's ($$$). The muffler is a little loud for my tastes but the fit from front-to-back is perfect. It looks like Chevs of the 40s might be selling Patrick's system? | | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | I am using the fentons with a Clifford Perf. water heated intake , 2 bbl Webber carb, and Patricks dual exhaust. More options...
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Aug 2010 Posts: 10 New Guy | | New Guy Joined: Aug 2010 Posts: 10 | Are the header tubes kit that goes to the intake only for cold weather? Anyone!
1954 3100 Hydra-matic 5 window! Straight Pipe Productions!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In almost all geographic areas and all times of the year, the intake manifold needs heat. Without heat, when the liquid fuel is vaporized there is coldness that is produced as part of the process ("latent heat of evaporation - "latent" heat of vaporization). If the intake is not warm, the vaporized fuel will condense, and this usually results in rough/hesitant acceleration.
| | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | I bought Fentons and the stainless exhaust system from Denise at Patrick's. They are great folks to deal with, and I'm very happy with the products, fit and sound of my 235. Great feeling to turn that ignition key after you do all the work and get it installed. | | |
