| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 111 | I noticed that either my turn flasher will work or my taillights but not both. Its like it does not have enough juice to power taillights headlights and flashers. I use a 3 pin 12 volt switch. I do not see a seperate switch for the emergency flashers so I assume the 3 pin switch controls flashers, taillights, and emergency flashers. Is there anything i can do to make it all work? I have tried switching the flasher fuse to no avail as well
1959 CHevy Apache
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am a bit confused here with some of the details. What is a 3 pin 12 volt switch? Are you saying that the flashers work with the headlights on or that they work with the front signals hooked up? | | | | | Joined: Apr 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 111 | Sorry for confusion, I meant the flasher itself is a 3 pin 12 volt flasher. I started to jack with it tonight and noticed that its gotten even worse, to get my taillights to work i have to put on hazard switch, which will activate taillights without flashing weird. Anyways I just got back from autozone and the kid said that the alternator is bad. I am hoping that the alternator is the cause of all the weird signals!!!
1959 CHevy Apache
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Hmmm... The alternator can definitly cause the "not enough power" issue and it's a good start to get it replaced.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
