0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
I noticed that either my turn flasher will work or my taillights but not both. Its like it does not have enough juice to power taillights headlights and flashers. I use a 3 pin 12 volt switch. I do not see a seperate switch for the emergency flashers so I assume the 3 pin switch controls flashers, taillights, and emergency flashers. Is there anything i can do to make it all work? I have tried switching the flasher fuse to no avail as well
1959 CHevy Apache
I am a bit confused here with some of the details. What is a 3 pin 12 volt switch? Are you saying that the flashers work with the headlights on or that they work with the front signals hooked up?
1951 1 Ton Completed
Sorry for confusion, I meant the flasher itself is a 3 pin 12 volt flasher. I started to jack with it tonight and noticed that its gotten even worse, to get my taillights to work i have to put on hazard switch, which will activate taillights without flashing weird. Anyways I just got back from autozone and the kid said that the alternator is bad. I am hoping that the alternator is the cause of all the weird signals!!!
1959 CHevy Apache
Hmmm... The alternator can definitly cause the "not enough power" issue and it's a good start to get it replaced.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
