| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69783 12/10/2006 12:32 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hello All , So I found my dad has an old Borg Warner 3 spdOD andI have no idea what year or what it will fit. The Numbers I took off of are as follows, On the Tailhousing # R10E-1A,W.G.DIV 48. All I could find on the Tranny it's self is #1A-7222, this was by the shifters. I have pics too but if anyone can go off this info please let me know. I have decided to go with a factory 3spd OD for my truck in order to try and get a better top end speed. I like bolt in stuff so that's the best route for my to go. Thanks!
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
#69784 12/10/2006 1:38 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like the one to me, should fit yer truck - look like this? - just check the mount hole spacing and the length against yer current trans, if they're the same ya lucked out Bill | | |
#69785 12/11/2006 11:06 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Danny, If it has a 4 bolt side cover it is the early style 55-65 non syncro first gear and will bolt in place if you have the long tail housing stock 3 speed. In the early 60's GM started using the short tail housing so you may have to shorten the driveline. If it has the 7 bolt side cover it is a later Saginaw - full syncro. It will require a fine spline front yoke and will have different shift arms on the side cover, it also may have a larger front bearing retainer. Either one will make you happy. Fred
