| | | Forums66 Topics128,260 Posts1,058,321 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Some years ago I bought a replacement grill for my 1957 Chevy pickup. It has been a few years since I removed the original one. I now have fiberglass fenders that seem to fit OK (with some wrestling). Now when trial fitting the new grill, the sides have a gap between the grill and fender(near the turn signal area). I remember the grill did not fit really tight there, but this seems excessive. Before I start trimming the fenders, I just wanted to know if there is normally any gap there. Thanks. Don
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | gap? the grill overlaps the surrounding "ridge" and bolts to the face of it - do you mean it stands out from that ridge or that there's a side to side gap? picture would help [but closer] ... the position of the fenders should really be set by the pieces above and below the grill that tie the fenders across the front Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Bill: From the photo it looks like your grill is tight to the body all around (nice truck by the way). Don | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | thanks, but just a driver, sold now for bus project money yes, the grill sits on top that ridge and [bolted from the back] gets pulled tight against it Bill | | |
