| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69733 12/07/2006 10:41 PM | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I'm about to reinstall my engine into my 1/2 ton. When the engine came out it had a front motor mount that looked "modified" with two plates of steel. I ordered the new parts and it just doesn't look right. The rubber mount has no support for the outer bolts and the shield doesn't fit very well around the rubber mount. This picture shows what I have and what I received. What was there when I got the truck is on the right, less the old rubber mount that fits inside. What should be used to mount this properly? http://good-times.webshots.com/photo/2096928780091368085GqrNhJ | | |
#69734 12/07/2006 11:01 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | What you are showing "looks" about right. Sometimes the rubber does take a bit of "finagling" to get it to set right. Here is a link to a cross section of the mount. (scroll down untill you get to figure 20) http://chevy.tocmp.com/1948_51truckshop/51ctsm0613.htm The lip of the bottom metal plate is "supposed" to support the top plate at the outside bolts or so I have been told. Wait a minute and somebody will come along who can explain it better than me.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
