Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
RAK
Offline
Any idea what the cost should be ? It's crunchy going into first and now there's a ticking sound in first and second when moving.Third gear is fine.Clutch and all seem fine.Thanks
Any shop will tell you that it depends on how bad the insides are. There's parts called "Hard Parts" inside. If some of those are damaged, it could get pricey. I had to buy 2 trannys to make one good one. But my friend only charged me 150$ to rebuild it.
