0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
#697156 11/22/2010 11:53 AM
So I found a ton of info on this site and got most of my VIN decoded.
The only place I'm stumped is the Production Order. I have a 1954 3100. The last 4 digits are 8010.
I know they added the month to it so would that mean my truck is the 10th off the line in AUG?
Also, if that is correct, one would be led to believe that it was in 1953 because 10th truck in August seems unlikely.
Any advice would be much appreciated.
Last edited by Woogeroo; 11/22/2010 12:22 PM. Reason: added year/model to topic so the interested parties would read the post
brandon s.
1954 Chevrolet 3100 1/2 ton
Wanna see it?
Walburg, TX
welcome to the shops Brandon, lots of info around here, might check the various pages about ID'ing your truck in the tech tips section
someone misled you, there is no month involved in the vin, the last part is simply the numerical order, as in it was the 8 thousand and 10th truck [of any kind] off the line at that plant - be the 7,009th actually as in 54 they started at 001001 wink
Here is the way the sequential production number works.
1953 through 1955 1st Series (Last of the "Advance Design")
TThe code changed significantly in 1953. VINs now had: Series (single letter); Model Year (last two digits of the year); Factory Code (now changed to letters); and Production Order symbols. Each series was separately numbered in sequence for that particular plant (Starting at 001001).
Example -- L54A001901
Series Model Year Factory Code Production Order
L 54 A 0001901
The truck in the example is the 900th 1954 1-Ton truck built at Atlanta.
Ahh. Copy that. Thanks for the help!
brandon s.
Wanna see it?
Walburg, TX
If the numbers start a 1001, 1901 would be number 901.
Brandon,
What is the full code you found on the plate?
Brandon,
Hi Tim. Thanks for asking about this. I got the "month" info from this site actually. It's on the Tech Tips page under "Deciphering your VIN". The paragraph reads:
"Starting in 1933, GM started adding a Month of Production code to the VIN. Stovebolts now had a VIN comprised of four elements: Factory Code; Model Year and Series (Note: Chevy added the 3/4-Ton back into the lineup for the 1937 model year.); Month of Production; and Production Order for that particular plant (Starting at 1,001). Production of a new model year usually started in the fall of the preceding calendar year."
My full VIN is: H54S008010
brandon s.
Wanna see it?
Walburg, TX
H54S008010 The VIN Buster
... Your 'VIN Buster' Results ...
Serial # : H54S008010
Mfg Year : 1954
Model : 3100 Comm 1/2 ton
Wheelbase : 116 inches
Plant : St. Louis, MO
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Mfg Year : 1954
Yep...did that. Got that info. Thanks!
brandon s.
Wanna see it?
Walburg, TX
