7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69712 12/06/2006 9:06 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | My friend is restoring his GMC 1ton 1961. He likes to find out what rearend gear options he would have for upgrading to higher ratios. He has 5.14 stock rear right now, but likes to be able to go on the freeways. | | |
#69713 12/06/2006 11:05 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Any 3/4 ton differential gear set from 1946-1972 will interchange with your friend's 5.14:1 without too much dinking around.
Most 3/4 tons came with 4.55:1 but a few came with 4.10:1 or 3.90:1. (mostly the automatics)
Just keep in mind that that truck is geared like it is to get your one ton of cargo moving. If he's planning on using the truck as a truck, he'd probably be better off with the 5.14 gears. (He could probably get away with the 4.55 ratio, too.)
Also remember if you make it go faster than the brakes are designed to stop, you could be in trouble. | | |
#69714 12/07/2006 2:14 PM | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | What Brendan said is true.
If you want to load it like a 1 ton, then when changing to a smaller number rear (like a 4.10) you won't be able to get your load moving (as well).
The 4.10 is available from people who part out(I got one recently) as is the 4.56. I've never seen a 3.90 available. I've heard of a 3.38 but think it is a myth. Havn't seen one myself... only read about people who's second cousin talked to a guy who saw one at a swap meet 10 years ago.
Consider looking on Pirate 4x4 or other such boards. There might be someone who would LOVE to swap you a 4.10 for your 5.14. The 5.14 is RARE, and wheelers and boggers love that tough old Eaton axle and the 5.14 is the holy grail of gears for that axle.
If you just want to go faster, and still want to load it up like a 1 ton, consider buying one of those Spicer auxilliary transmissions that are in the for sale board... or some other aftermarket auxilliary tranny.
I have 19.5" tires. That helps things go faster. | | |
#69715 12/08/2006 6:41 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What motor is he running?
I have a 1-ton that has 3.73 gears in the rear (swapped axle). The guy I bought it from said it was no longer drivable able he swapped rears.
If he is running a stock 235 he may want to think about that.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#69716 12/09/2006 12:14 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can I throw a wrench in the works? Being a GMC, there's a good chance it may have a Spicer axle rather than the Eaton. If it is, most likely it would be a Spicer 60. Gears are readily available for those axles, check any rear end supplier or off-road shop.
Bill Burmeister | | |
#69717 12/09/2006 7:37 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | The rear according to the manual is a Corporation HO72 and not an Eaton or Spicer.
Are there gears readily available anywhere or are there any specialty vendors? | | |
#69718 12/10/2006 1:51 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The HO72 was manufactured for GM by Eaton (Detroit Gear and Axle). To my knowlege, parts selection is kind of slim for these rears, along with it's HO56 and HO33 little brothers. I only threw out the Spicer suggestion as a possibility, as it isn't unusual to see them in '55-'77 GMC trucks.
#69719 12/10/2006 3:39 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd forgotten, but my '55 1st GMC had a Spicer under it when I bought it. I replaced it because the pinion bearing failed.
