2 members (dinosoar, 52Carl), 82 guests, and 3 robots.
Topics128,127
Posts1,056,677
Members48,452
Anyone know where i can find factory torque specs for a 52 1/2 ton? I'm starting to put the front suspension back together with new parts. i want to make sure everything is torqued correctly as i tend to want to use the old "calibrated arm" technique.
Do something! Even if it's wrong!
You can find with some searching the info here.
http://chevy.oldcarmanualproject.com/#year
Drew
Cool! found what i needed. thank you!
