7 members (Lightholder's Dad, 1955 1 Series, 55shaker, DuckRancher, Jon G, 2 invisible), 67 guests, and 3 robots.
Topics128,202
Posts1,057,409
Members48,471
How many splines on a 57 GMC Dana 44 rear axle shaft?
19 or 30? I have a friend needing a new carrier for his 57 GMC and I have a source for a 30 spline power lock from a 63 GMC...
Probably 19, but the only way to tell for sure is to pull one out. My '55 Willys had a 10-spline D44, they went through several evolutions. If you are running open carriers you can just swap the spider gears, but I dunno with a powerlock.
Paint & Body Shop moderator
Kenny W,
If the splines are not the same and both axles are Dana 44 You can just swap the spider gears. Just make sure the carrier is for the gearset You have, as long as there are 2 carriers, one for the gearsets from 2.87/1 up to 3,54/1, pinions ranging from 15 to 13 teeth, and another one for the gearsets equal or higher numerically than 3,73/1( gearsets with 12 - 8 teeth).
4onthefloor,
As far as I know, in the dana44 rear end all spider gears are interchangeable, as long as You're playing with the right gears for the right carrier, one leggers can take all for this use and the limited slip only with limited slips. But the smaller ones and the inner shaft are the very same stuff for all of them.
Alexandre Garcia
He is going from an open carrier to a power lock so swapping spider gears I dont think will work. I know any open carrier for 3.07-3.73 ratio would be easier for him but was trying for the power lock as a prefered carrier.
Kenny W,
As I said before, You cannot swap spiders from one leggers to lockers, but You can try to locate just the spiders with the desired number of splines for the locker and do just swap then in the locker carrier.
I have seen the indication that a carrier would go from 3.07 to 3.73 in catalogs, but check it out carefully, been working with danas for a while, and occasionally I have a 3.73/1 (11/41) rear in a dart here, it does not use the same carrier as the 3.07.
Alexandre Garcia
