3 members (GIJOE298, Gray_Ghost, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
#696204 11/19/2010 2:52 AM
ok so to not hijack bigtonys search for hinges thought i would ask here...
on the 47-54 clam doors is there really any difference in the hinges in respect to different years???
i have been told that there is a difference on the upper hinges but noone seems to know what they are,,, then when talking to a guy last night i was told that its the lower hinges that are different but he didnt know whet the diff was,,,,,,
i know G is gonna compare his sets this weekend so thank you
and all the hinges for the AD burb have been the same.
so if there is what are they?????
On the 47-54 clam doors is there really any difference in the hinges in respect to different years???
According to the parts list, yes.
1947/50:
The hinges are Left upper end gate #3809089 & Right upper hinge #3809090 These are complete units. ([color:#CC0000 ]
These are the repair parts:
They also need: PIN upper door hinge link #3800503
Washer #3800504
Bearing #3800505
[color:#CC0000]1951/54:[/color]
The hinges are Left upper end gate #3808047 & #3808048 I believe these are complete units too, plus they need to have the housing installed on the Suburban to work. (Tentatively confirmed, I have a NOS one to compare.) Stamped on the end gate side of the hinge is #3808059 and the tag is gm3808047
They also need: PIN, hinge link upper #380864 (2)
WASHER,hinge link upper #3808065 (4)
HOUSING hinge left & right upper #3808067 & #3808068
SPACER,#33808066 (2)
I have been told that there is a difference on the upper hinges but noone seems to know what they are,,, then when talking to a guy last night i was told that its the lower hinges that are different but he didnt know whet the diff was,,,,,,
The lower hinges are the same:
1947/54:
Lower half on body #3808361 (2)
Left lower end gate #3807971 & Right lower end gate #3807972
I know there is a pin and acorn nuts to put the two halves together, but I did not find them on the list.
The next question will be: Is there any differences in with the upper and lower tail gates between the years?
The answer according to the parts list is no.
1947/54
END GATE :
Upper half #3808211
END GATE:
1947/54
Lower half: #3807954
Now I have my hands full. I am going to take apart my upper end gate and compare the hinges that I have. I will take pictures, but I won't be able to post them right away. I have never removed hinges from a 47/50, I have removed several from 1951/55's. From just looking at them casually, they appeared the same. I now see they added reinforcement to the 1951/55 years. ........g
After doing some research, I believe that the hinges on ebay right now are the correct ones for the 1951/54 suburban end gate. They are marked for the 1951 suburban.
each upper hinge bolted to the body with 3 or 5 bolts depending on the yr of ad
1949 SUBURBAN
A post has been deleted. Buying & Selling parts is done in the Swap Meet.
Ok I confirmed that they did make to different hinges for the suburban ad the parts manual states.
Unfortunately, mine are welded in :mad: I knew there was a reason I was looking for a set. I have not opened the rear hatch for a while. grin I do not think it will be a problem to install the later model hinges in the 48. I will search this out, but if GM could do, why can't we? It's not that big of a difference. The end gate lid uses both of the hinges so it is only the top header that needs modification. I did a little digging and I have an extra set of the later hinges, so far no early hinges.
well, the newer style got here. in a chance. I can cut the header out of my 51 and do a swap with the 48/49
I prefer the og. hindges and I have not yet started work on the truck so, I can hold that off till the spring and hope someone finds a set laying around. then I will sell the set I have.
thanks for checking and confirming what I confirmed. now just to find the hindges needed.
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
thanks for the info guys,,,,,,,
can anyone post pics of the 2 styles for reference,,,
i have a set taken off my 49 and and an extra set ill get pics of later
