| | | Forums66 Topics128,086 Posts1,056,097 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Hankdogg,
I recognize the bracket in the upper left hand corner as the lower alternator bracket. Is the bracket in the upper right hand corner the upper alternator bracket? If, so what is the U-shape for? just curious. It looks like you put a lot of thought and effort into these.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Dale, it's all the same lower bracket, just different angles of the same. Looks better now that it is painted. Used a old 250 upper bracket after I put a little bend in it for the top bracket.
Hank | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I agree, more fun to fabricate I also used a rework of original bracket to mount Alternator | | |
