11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#693438 11/09/2010 6:17 PM
Hi there,
I am a novice restoring a '54 Chevy truck. I swapped in a '55 engine and purchased the short water pump and pulley so the radiator would fit. I installed it, placed the spacer on next to allow clearance for the harmonic balancer and then attached the fan. My challenge now is the really small space in between the fan and the radiator and getting them both to fit.
Does anyone out there have any tricks that have worked to get the radiator to line up without being obstructed by the fan blade?
Any ideas are appreciated.
Carlos
Riding in the Passing Lane
Ive never done this but the guy's say that the coversion kit that's available now uses the original water pump & put's the pump in the higher up position.
1972 Chevy c10 Cheyenne Super
search for: +water +adapter +plate
You'll find more than a few posts on this topic.
I have been running a 55 engine in my 52 with a shortened water pump, and the original 216 fan clears by about 1/8" on both pulley and radiator.
Would I do it again now that we know about the water pump relocation plate?
Absolutely not!
Seems to me short shaft water pumps should become extinct with the superior water pump adapter plate now on the scene.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
ODSS President
ODSS President
~ Cosmo
1949 Chevy Half Ton
Here is an easier LINK
My Blog
I appreciate everyone's feedback. IT seems my fan now needs to be tweaked a bit to avoid hitting the harmonic balancer on the bottom, the radiator in front, and possible even shortened to not nick the fixed drain outlet from the bottom of the radiator. Hopefully this is the last tweak before I can get running.
Some people find that after getting over all the above hurdles, it overheats at idle because the fan is too low. I don't mean to discourage you but one of my friends has this problem too.
1951 1 Ton Completed
