6 members (carbking, 39Master85, Dennys28, baldeagle, Hotrod Lincoln, Otto Skorzeny), 74 guests, and 4 robots.
Topics128,180
Posts1,057,149
Members48,464
#695715 11/17/2010 4:34 PM
What kit does everyone recommend for a 1946 truck? I know there are many kits out there, just wondering which one everyone is liking the best.
I dont know if its the best,but I had good luck with a TCI frontend.Only problem that I had was solved with an E mail to customer service,and that was what power steering pump to use with the R&P setup.
I used a subframe from Flatout Engineering that uses Corvette C4 front suspension componets. They are readily available and are made from forged aluminum, so they are very light. It also uses the C4 rack and pinion and brakes.
