| | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | When replaceing the fender welt on the rear fenders of my 54 pickup do you use any sort of adhesive to hole the welt until you get it bolted in or is it just a dry fit? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope, wasn't used on the pickup trucks. If you insist on having something between the rear fender and bed side then you might concider using tar paper/felt paper which is what they used for an anti-squeak gasket at the front. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you opt for installing the welt, I'd suggest you use weatherstrip adhesive to secure to fender flange - makes it a whole lot easier when bolting up the fender. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I don't agree with you Denny, at least for not all of the ADs. I bought a 51 3600 for parts when I was restoring my 53 3100. The 51 was a old farm truck with the bare essentials and it had fender welt on the rear fenders, in terrible shape but they were there. I doubt it very seriously if a farmer would have put this welt on the truck. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy Ron, that subject has been discussed literally hundreds of time on this site and a few of the others that I frequent. I’ve got a friend that believes that also because there was a ½ ton at the golf course that he worked at when he was a kid. After all these years you really don’t know what the previous owners or their kids may have done. Visually I don’t see why they would use it at the rear because of the angle that you normally view the joint from. It’s a different story at the front because you see both sides of the joint straight on from the same angle and any discrepancy is quite obvious. If fender welting were installed at the factory you would see a lot more examples of it. Instead what we find with nearly all of the AD’s is the fender bolted directly to the bedside and on very rare occasions one with beaded fender welting. It just seems logical to me that these odd balls are because a previous owner thought it would look better with the joint in trim. Back when they were relatively new and the fasteners weren’t rusted tight, it would have been a simple matter to loosen the screws and slip welting in place. Would have been a nice easy project for after supper one evening. So I guess what I’m saying is, unless I see documentation that some came from the factory with rear beaded welting I’m gonna go by what I’ve seen and what nearly all of the people that I’ve talked with have run into. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have parted/sold 10 A-D pick-ups and 13 bigger trucks in the last two years, the trucks were spread over 4 states and I have not seen any with fender welt on the rear fenders. If you look at your front fender welt it is die stamped with the appropriate cut-outs for bolts and bends. The point being if it is factory they would have done it the same way for the rears and someone would have some to show us. When you build 300,000 + trucks a year in multiple plants if you don't need to add something like that you don't. Think of it this way if it cost .50 cents a truck and you didn't need it would you add it?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't any of youse have the 47-55 assembly manual? doesn't it show details like the welt installation, either/both front and back?
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I use it all the time do you have a page number? I don't recall seeing anything on beds/rear fender installation in the manual? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that was a question Brad not a statement, I'm not into AD's - suprised the 47-55 manual wouldn't show installing fenders, in the 55-59 manual the rear fender install is under 'sheet metal', not with the bed assembly, and specifies application of "sealer" under the bolt flange
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Bill, Mine was a question too as I did not recall ever seeing anything in 47-54 version it has almost no information in it on beds.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Check out the 47-55 Chevrolet Truck Factory Assembly Manual
Section 11 (CAB AND SHEET METAL INSTRUCTION MANUAL)
Sheet 19.00 - REAR FENDER TO BODY & CENTER BRACE INSTRUCTION Models 3102, 3103, 3104, 3112, 3604, 3804 (pickup truck models are in bold) No anti-squeak is shown (rear fender is shown)
Sheet 20.00 - REAR FENDER & BODY ANTI_SQUEAK INSTRUCTION Models 3105, 3106, 3107, 3116, 3805, 3807 (all panel body trucks) Anti-squeak is shown (rear fender and beaded fender welting is shown)
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I figgered there'd be an answer in the assy manual - interestingly, the TF 55-59 manual also shows the pickup fenders in section 11, sheet 19
Bill | | |
