2 members (TexasA&M48Truck, stlcardinalsguy), 79 guests, and 1 robot.
Topics128,132
Posts1,056,732
Members48,454
#695344 11/16/2010 8:18 AM
Has any one found or know what to use for the front disc brakes for a 3800 1 Ton with the 3500 lbs Axle. I need to know what discs, calipers, and bits and pieces to make it all work. What vehicle it came off of or # of parts used. Also which power duel master cylunder the floor to use with a 14 inch rear end with brakes. There is no info in all of the forums list I have looked at and 3/4 and 1 ton trucks seem to be over looked. There are lots of info for 1/2 tons. Please help.
1953 1-Ton Canadian Model 1434
More pix on Photobucket
This is the best progress I've seen...
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=603612#Post603612
Its still not done but if you read through it there is a ton of good information in there.
I may drive a VW, but I love my 52 Truck...
trihawker:
Consider doing what I did for the rear brakes. I have 1 ton front brakes on my 3/4 ton.
