Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (qside, crenwelge), 218 guests, and 5 robots.
Topics128,282
Posts1,058,497
Members48,490
Hi. I am trying to replace my ignition cylinder for my '64 Chevy truck. I unplugged it from the back but how do I get the other part of the plug off of the ignition cylinder? Thanks in advance-
What other plug? There should only be one plug. At Least that's how it is on my 61. 4 wires. Ignition, Acc, Battery, Sol. Or are you talking about the cylinder itself?
If you're talking about removing the lock cylinder from the ignition switch , there should be a small hole just to the side of the keyhole on the ignition switch . You stick an appropriately sized metal rod into the hole and twist the unit and the lock cylinder should come out of the switch .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
Just to add a little extra, turn it counter-clockwise. You will also need the key to do it.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
The cylinder itself...There are 2 holes off to the side...does it matter which one I use? Thanks guys.
The hole we're talking about is on the face of the ignition switch ( where key goes in ) . I think ( can't say for sure without going to look ) my switch only has one hole ? I could be wrong ?
I've seen the switches with two holes only one of them will work. Feel around for the spring with your paper clip. You won't wreck anything by being in the wrong hole.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Does the plug on the back just pull off or is there a trick to that also?
Thom Masterson
Got it...thanks guys. Paperclip in upper hole, turn counter clockwise and bingo!
