4 members (BC59, Hotrod Lincoln, FishinToms53, Bill Hanlon), 73 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Sometime ago someone mentioned that he machined a 235 crankshaft from a later (full pressure) engine to fit a 216 engine.
I am not sure if it was mentioned here or in another forum.
Does anyone know anything about this modification?
I am planning to rebuild the 216 from my Greek truck and I should like to make it as reliable as possible so this should be a good idea. The Greek legislation does not allow any other size engine in vehicles, other than what the original size was, otherwise I should prefer a later 235.
Thank you
Jianis
You'll have to have pistons made to suit. The 216's lower deck makes the 216 piston too tall with the new stroke.
Former Workshop Owner
I believe, certain year 235's can be disguised to look just like a 216. There have been post's on this topic.
Good luck
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
1941-49 235s look just like 216s from the outside. They are 1/8" taller.
My Blog
the early 235's 42-53 look exactly like 216's. the WWII chevy army trucks used a 235 and after the war several europian countries used them so try contacting military surplus/ colectors, etc. and you should be able to find a 235.
I should add, 1941-49 235s are still splash engines, not that I have anything against the splash system.
It was not the splash system that killed these engines, but the fact that all splash engines used cast iron pistons. This puts extreme load on the rods at today's speed limits.
If aluminum pistons are used during the rebuild these are very reliable engines.
If you use a 1941-49 235, everything but the block, crank and cam can be used from your 216.
garandboy is not quite correct in his post. only 1941-49 235s had a full side cover like the 216. These 235s can be found in most 1 1/2 and 2 ton Chev trucks.
My Blog
I stand corrected, still learning blush dang
Panic Lucas Garand and Dave
Thank you for all the ideas.
Unfortunately the Greek ministry of transport has a mean system to prevent that people are tempering with stolen car engines.
They either require a bill from a garage installing your engine mentioning the size engine number age and manufacturer etc.That will set you back some $ 2000 for work and taxes...
Another solution is getting an engine from an official dealer with a bill mentioning all the above.
Finally after the engine is installed it has to be checked and they make a trace of the engine Number with pencil on a piece of paper that goes in your cars file.
I know all this as I had to install a re manufactured engine engine in my 68 Volvo a few years ago.
Dave
I am planing to use aluminum pistons as they are lighter so they have lower inertia but will it really make all that difference?
By the way if I ever get the time I should like to travel around the USA with my Dutch Fleetmaster.
Jianis
Are you wanting to make your 216 pressurized? Or are you looking for the extra cubic inches?
Yes.
Don Stocker
The idea is to make the 216 pressurized.
Jianis
I have seen posts about some shops doing machining to make a later 235 crankshaft fit. Is it possible for a shop to cross drill an old 216 crankshaft?
1951 1 Ton Completed
