6 members (Otto Skorzeny, Bill Hanlon, Bisbee, 54farmtruck, dt235sd, klhansen), 103 guests, and 3 robots.
Topics128,148
Posts1,056,811
Members48,454
#69444 12/01/2006 6:22 PM
I have a 56 TF with a 350 motor and 400 tranny. I purchased a 273 posi rear end out of a 78 Trans AM, with the intent to find 308 posi guts to swap out. I'm having difficulty locating the 308 guts. My 56 will be street driven with some highway use, so I'm wondering just how effiecient or ineffiecient the 273 would be given that scenario?
Any input would be welcome.
Paul
1956 Chevy Task Force Webshots
My wife puts knots on my head faster than I can rub 'em. That's why I ask knot-headed questions.
About 12+ % fewer RPM's but it might get you out of the torque curve of your engine which you don't describe except as a generic 350. It would help you to know what engine was in the Trans Am.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Riding in the Passing Lane
I think it will be just right with normal size tires on it. I run a 70 stepside with 3.08 rear & 700-4r o-drive & it pulls real good. It is a pleasure to drive.
1972 Chevy c10 Cheyenne Super
Z
Z Offline
a 700r4 has a much lower first gear than a turbo 400.
Quote
What kinda revs are you turning in that truck...??? About 800 rpms at 100 mph...?!?!?! eek
I have a 2.73 rear in my '73 Monte Carlo , while it keeps the rpm down and allows for very quiet running , the gearing is so tall that the car has little "get up and go" . I've pulled a small caravan with it and it was working hard all the time , regardless of speed.
I think of a truck as being a tool , so it needs to be able to tow a load , carry a load and do it without too much difficulty.
So ......... I think a 350 with a 700r4 and a 3.7 or even a 4.1 rear would be a very handy combo. The overdrive would bring the road gear back close to 3.0.
Great off the line pull and a long leg for the open road.
