0 members (), 247 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#694335 11/12/2010 7:57 PM
Has anybody tried to put one in a 55-59 TF truck? If so what years would be a good donor trucks? I was thinking late 90s maybe? will it fit behind rear diff?
Brad
That's what I have under mine. It came from a '91 as I recall, but any '88-'98 should work fine. If you're using the riginal 6 lug pattern wheels, try to get one from a 4x4, it has a slightly larger plate on the cable that holds the spare. Mine came from a 1/2 ton 2wd, and we had to add a couple of "wings" to the plate to allow it hold my spare wheel. I used the holes from the original carrier to install it, lined up just fine with plenty of room between it and the axle with a 30x9.50x15 tire on it.
Bill Burmeister
LONGBOX55 #694639 11/13/2010 11:13 PM
Apprentice
Apprentice
How timely this subject is! I am considering putting the spare tire under my son's 59 using a winch from a newer truck. Thanks!
