| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Can you tell me what type of rear end this is? I have a 62 C10, straight 6, 235, 3 speed. Stamped on the rear end is MA 6. I could not find a replacement gasket anywhere in the parts magazines. Does anyone know how I can find one? Thanks for your help!!! http://www.facebook.com/photo.php?f...t=a.102304093122655.4992.100000291951906
Thom Masterson
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Standard Eaton HO33 with the 3.90 gear. Should be able to get the gasket at the local pats store, or Jim Carter part# ME292 as shown in the link jmoore posted.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Is it possible that this rear end could end up or even start on the back of a 3/4 ton as opposed to a 1/2 ton?
Thom Masterson
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | How many lugs does it have? If it has 8, then yes. But not likely. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 |
Thom Masterson
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a 1/2 ton differential.
