5 members (MickeyP, papas52, dt235sd, GA Boy, dgrinnan), 76 guests, and 1 robot.
Topics128,169
Posts1,057,035
Members48,458
The 1966 GMC Suburban has air bags in it. As far as I can tell, nothing has been cut or altered in the front and other than the rear axle being on the wrong side of the leafs.
I want to go back to stock coils in front and flip the rear where it belongs.
The question is: Has anyone had experience with ordering coils. Mook, I think was the only thing I found that did not say "for 1/2 ton PUs only"
Are most of the suspension items that fit a 1/2 PU interchangable with Suburbans? I don't want to blindly take the person that answers the phone to be completely correct.
Thanks in advance
It's a 1966 GMC Suburban
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Jon, give Golden State pickup parts a call and see if they can help you.. they deal in suburbans and pickup's.. they are in carson city NV. 800 235-5717
wayne
Working on a 1952 Chevy Suburban
Jon 5, I am in the process of refurbishing a 66 Suburban, and basically every thing from a 1/2 ton truck is the same for the Suburban. Your Brake and Fuel lines will be different, but most everything else, especially from the doors forward. I saw Front Coils in the Summit book, and I got the same ones from a local parts store, and they are made by Moog. Is yours a Chevy or GMC? I thought most of them were Coil Springs in the rear. There was some discussion on this in an earlier post not long ago. Good luck
