| | | Forums66 Topics128,261 Posts1,058,327 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I have a 55 chevy 3100 truck with the 235 engine and the original foot stomp starter. The engine runs great as long as you keep the starter engaged. But as soon as you let off the starter the engine goes dead. I had all the wirng off the cab at one time when I had the cab off the frame. I have the dark green wire going to the coil and the other wire going to the wire that comes off the starter switch. Do I have this wired correctly? Thanks for any help on this problem.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like somethings wired wrong, although I can't see what it would be right now.
To check I would run a fresh wire from the coil to the battery, remove the existing one that came from the ignition switch. A wire with with alligator clips is fine. Be sure you still have the wire already from coil to distributor. Other than plug wires you'd need nothing else to see if it'll run. If it will run when "hot wired" as described above you're then one step closer.
Let us know,
Grigg | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You are not getting curent from the ign. switch to the resister to the coil. When the starter is engauged the coil gets current from the bypass on the side of the starter switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I hot wired from the battery to the + side of the coil and the motor runs great I must have had a brian fart not to have done that already. I think I have a bad resistor because everything is wired correctly according to the assembly manual. Anyone know where I could pick a resistor up at? I don't want to run it to long like this because it will burn up my points quicker And thanks for helping me out with the problem.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, that's the symptom when the resistor is toasted, runs when getting power from the starter, dies as soon as you let off it ... the resistors are available at NAPA or other FLAPS
Bill | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | thanks for the info Bill, I will be picking one up tomorrow | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I figure I would update on the engine problem. I replaced the ceramic resistor on the fire wall and the engine runs great without having to straight wire the coil. Napa had the part for $10.50. Thanks to everyone who helped me out on the problem, great forum. | | |
