2 members (dt235sd, Jon G), 50 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#69430 12/01/2006 12:44 PM
Anybody got a handle on the average volume efficiency of a 235?? 65%, 70%, 80%
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#69431 12/01/2006 2:49 PM
What is volume efficiency?
#69432 12/01/2006 3:30 PM
any 4cycle engine has an efficiency of about 20 - 25 percent
#69433 12/01/2006 4:03 PM
52pu,
From what I understand, the volumetric efficiency of a average naturally aspirated engine is somewhere between 80 and 100%. These figures change with modifications to carburetor, cam and exhaust system.
I sure don't know where the old stovebolt fits in this range, and don't know how it would be measured...maybe a flow bench!
If I was going to run my old truck at Talladega I might be concerned, but the occasional trip to the land fill is about it for me! smile
Stuart
#69434 12/01/2006 5:30 PM
Riding in the Passing Lane
Iv,e always understood it,s about 18%. Thats how much of the potential power in a gallon of gasoline acually gets used in makeing power. If you can find a way to improve it you can save the world & get rich.
1972 Chevy c10 Cheyenne Super
#69435 12/01/2006 5:36 PM
Although I don't know 'nuttin' on this subject, I think there are two different things being referred to here.
Volumetric efficiency (VE) is the 'breathing quotient' of an engine, and different (I think) from the plain old efficiency of a internal combustion engine.
Stuart
#69436 12/01/2006 5:42 PM
no, Stuart's on the right page, the 18% is thermal efficiency or something
figuring volumetric efficiency
in relation to designing yer own engine
seems a little esoteric for our mundane 235's grin
#69437 12/01/2006 8:19 PM
Supercharge it just supercharge it grin grin grin
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#69438 12/01/2006 9:50 PM
My 216 is a wopping 82 horse power, what more could you ask? Looked at Tom's equations, thought my head was going to explode. If I can't do it in my head...I don't care.LOL
#69439 12/02/2006 1:48 AM
This would vary considerably with the rpm. I am sure that at low rpm the efficiency would be reasonably close to 100 per cent, but would drop off as the rpm increases.
It is interesting to note that on some of the special built racing engines a naturally aspirated engine can exceed 100 per cent efficiency. Far beyond my capabilities I am afraid, and very expensive too.
#69440 12/03/2006 3:54 AM
Volumetric efficiency is the percentage of the total piston displacement that actually flows through the engine at normal running speeds. Intake and exhaust restrictions, plus cylinder head design, valve timing, and a bunch of other things have an effect on how much air, fuel, and exhaust gas flows in and out.
Basically stock engines, without extensive porting and polishing, and with stock camshaft profiles and valve sizes usually run from 85% to 90% volumetric efficiency at normal running speeds, as measured by the flow meter on my dyno. With lots of head work, radical camshaft profiles, and high engine speeds, plus tuned headers, I can get slightly over 100% VE on my roundtrack race engines. That's all they're good for, though, "Go fast and turn left!"
