8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren),
83
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69430 12/01/2006 12:44 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Anybody got a handle on the average volume efficiency of a 235?? 65%, 70%, 80%
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#69431 12/01/2006 2:49 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | What is volume efficiency? | | |
#69432 12/01/2006 3:30 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any 4cycle engine has an efficiency of about 20 - 25 percent
Bill | | |
#69433 12/01/2006 4:03 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 52pu, From what I understand, the volumetric efficiency of a average naturally aspirated engine is somewhere between 80 and 100%. These figures change with modifications to carburetor, cam and exhaust system. I sure don't know where the old stovebolt fits in this range, and don't know how it would be measured...maybe a flow bench! If I was going to run my old truck at Talladega I might be concerned, but the occasional trip to the land fill is about it for me! Stuart | | |
#69434 12/01/2006 5:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Iv,e always understood it,s about 18%. Thats how much of the potential power in a gallon of gasoline acually gets used in makeing power. If you can find a way to improve it you can save the world & get rich. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69435 12/01/2006 5:36 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Although I don't know 'nuttin' on this subject, I think there are two different things being referred to here.
Volumetric efficiency (VE) is the 'breathing quotient' of an engine, and different (I think) from the plain old efficiency of a internal combustion engine.
Stuart | | |
#69437 12/01/2006 8:19 PM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | | | |
#69438 12/01/2006 9:50 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | My 216 is a wopping 82 horse power, what more could you ask? Looked at Tom's equations, thought my head was going to explode. If I can't do it in my head...I don't care.LOL | | |
#69439 12/02/2006 1:48 AM | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | This would vary considerably with the rpm. I am sure that at low rpm the efficiency would be reasonably close to 100 per cent, but would drop off as the rpm increases.
It is interesting to note that on some of the special built racing engines a naturally aspirated engine can exceed 100 per cent efficiency. Far beyond my capabilities I am afraid, and very expensive too. | | |
#69440 12/03/2006 3:54 AM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Volumetric efficiency is the percentage of the total piston displacement that actually flows through the engine at normal running speeds. Intake and exhaust restrictions, plus cylinder head design, valve timing, and a bunch of other things have an effect on how much air, fuel, and exhaust gas flows in and out.
Basically stock engines, without extensive porting and polishing, and with stock camshaft profiles and valve sizes usually run from 85% to 90% volumetric efficiency at normal running speeds, as measured by the flow meter on my dyno. With lots of head work, radical camshaft profiles, and high engine speeds, plus tuned headers, I can get slightly over 100% VE on my roundtrack race engines. That's all they're good for, though, "Go fast and turn left!" Jerry
