5 members (Mike B, ShopRag, Youngin' Tut 59, klhansen, 1 invisible), 98 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
I
I Offline
Just a quick question. I have a chance to replace my original 216/3speed/etc. with a 56 Hydraulic lifter 235/ t5 and open drive. My issue is with the 235, it runs good but the oil pressure at 1800rpms/60 mph is 25lbs. specs say 35 at speed. what to worry about?
ia49 #693689 11/10/2010 3:13 PM
I have a 56' 235 in my 49' 3600 and it runs at 25lbs also.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
The Idle oil pressure tells more about bearing clearances.
If you get about 15 PSI at idle you are good.
My Blog
I
I Offline
THX for the replies. She runs at about 15 lbs at idle when warm and 25 lbs at 2000 rpms. It's a little hard to tell as the guage messures 0 to 100Lbs. THX again.
