| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 38 New Guy | | New Guy Joined: Jan 2009 Posts: 38 | Well after ditching the original carb (rebuilt and cleaned it) I finally got my 51 Chev to run right with a carb off an 80s AMC. I took it down the road for a victory lap. It runs ok although power does seem to be lacking. Could be because the throttle isn't hooked up properly (coat hanger). Anyway I am just stoked that I can drive it. There is a ton of evidence of farmer engineering on this puppy. Wiring everywhere, lots of jury rigged repairs. I can't say I am helping much there since I've done a few myself since getting this thing. I got a free set of military NDTs for the back. They aren't weatherchecked, tread is about half an inch at least in the centers. Getting them mounted though wasn't cheap. I got a set of freebie steer tires for the front. The tires are all a bit larger than the originals. The rears are 11x20s and the fronts will be 10x20s. With the smaller 8.5x20s the truck has a bit of rake to it now. There is a crap load of shake in this thing, could be tires, could be something else. Seems to get better with speed. The plan is to get a plow mounted on it for winter and use it for hauling logs into the saw mill. A few pics of my joy ride today: Front of the truck. As you can see it needs a bumper. Another shot of the truck. Side profile Pic of the dash. You can see wiring going every which way here. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think I'd buy a box of inline fuse holders to start....
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Nice truck the dump box looks to be in great shape.
Wiring can nickel and dime you to death if you plan on a rewire witch it looks like you are in need the pre built harnesses turn out way cheaper in the long run. E-Z wire is good and seems to have the best pricing but even the more expensive ones are a bargain. A friend and I rewired my 64 GMC and although my friend is very good at automotive wiring and did a bang up job in the end it would have been much cheaper to use any one of the aftermarket harnesses available. Oh and other than a couple of days room board and beer that would have all happened anyway my friends’ labor was free.
| | | | | Joined: Sep 2010 Posts: 33 New Guy | | New Guy Joined: Sep 2010 Posts: 33 | Where are you at in WI? I live near Bruce in Rusk Co. If you ever find a plow for your truck I'd like to see pictures. I'd like to find one for my '52 2-ton. I checked out your blog - nice. I have one also. Here's a link to one of my truck stories. http://thewritingwredneck.blogspot.com/2010_09_01_archive.htmlIf you click around on the archives section along the right side, you'll see we both enjoy the same type of living. Good luck with the truck. | | |
