0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | So I'm trying for a pretty original look with my '50 1/2-ton pickup but I have an opportunity to buy some pretty nice '57 15" wheels with good condition white wall 215/75-15 radials on them for pretty cheap. I originally wanted 16" wheels because I think they look more legit, more 'old farm truck'. Do any of you have a setup like the one I'm proposing, i.e. 15" wheels and 75-15 tires on an AD truck, and will it look okay? Anyone have photos of this setup? Cheers, Nick | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 215/75R15 235/75R15 First pic truck has lowering springs Second pic stock springs. the 215 are about 1 1/2" shorter in diameter the 235 are almost 29" diameter, pretty close to stock. Good Luck | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Thanks DADS50
Hmmm... so I'm basically talking about duplicating the setup on the top photo without the lowered springs... I mean, the wheels look small to me, but I can't tell how much of that effect is just the lowered springs...
So you're saying that "215 (on 15" rims) are about 1 1/2" shorter in diameter" (than 16" wheels w/ stock tires)?
Thanks again for the input. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't think they will look good at all. I like the 235-75x15 on all the old trucks. A lot depends on the width of the wheel also. 8 in. wheels are even a little to wide for the 235's. 7 in. work best. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Sounds like good advice. From your input and DADS50's photos, I'm leaning towards passing on this one. Cheers, Nick | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I was told the 225/75 tire duplicates as close as possible the original tire size.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Joe, I'm assuming your 225/75R tires are on 16" rims, yes? Cheers, N | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | So you're saying that "215 (on 15" rims) are about 1 1/2" shorter in diameter" (than 16" wheels w/ stock tires)? The 215’s are approx 1 1/2 shorter in diameter than the 235's on the 15's. I believe the stock diameter is 29", but maybe a wheel and tire guy can confirm. caculator In my view the 215's on a stock height truck and springs would not look right. The tire would not fill the wheel well. But that’s just my opinion. Good luck | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The tires I am talking about are 15" tires. Sorry, I forgot to mention that. No offense to the other contributing answers to this question, but, in my opinion, 235 tires look too big, at least, for a 37 1/2 ton pickup. I had some on my truck and they were over powering. They might look better on a 47-54, but I would be careful about oversizing the tires, if you want a "stock" look.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | nrdesieyes check out post 3 on this link It shows a 50 on 16's. if you decide to go that route. For when your bolting your farm truck in east palo alto  Good Luck (Thank you, for those of you who served) | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Yeah, that's not the look I'm going for... Thanks to all for the input. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | 215/75R15 235/75R15 First pic truck has lowering springs Second pic stock springs. the 215 are about 1 1/2" shorter in diameter the 235 are almost 29" diameter, pretty close to stock. Good Luck How much lower is the truck in the top pic than stock? and in the other pics in that folder you had some longer studs on your rotors did you do that to clear the disc brakes on a stock 15" wheel?? if so do you have the part number or what the longer stud came off of ill probably have to do the same thing | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The previous owner lowered the truck. I think it was a 3" lowering lief spring kit he put on front and back. And the tires and wheels lowered it about another 1 1/2" The longer studs were needed because of the LIERS, CROOKS, and THIEVES at Stockton wheel. Those are new wheels that were supposed to be custom back spaced to clear the brake kit. Well after waiting months and months for the wheels…. they didn’t clear the caliper. The only way I could use them is to use 1/4 inch spacers. Needed longer studs and had to go to a larger diameter. It was a total nightmare dealing with them. They refused to make the order right and straight up lied. I ordered the longer studs from my local CARQUEST auto parts. I don’t recall the brand. I took the old stud with me so they could match the shoulder diameter and length. the red wheels and black wheels are 15" this thread talks about extended lug nuts. May work for you Good luck | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | The previous owner lowered the truck. I think it was a 3" lowering lief spring kit he put on front and back. And the tires and wheels lowered it about another 1 1/2" The longer studs were needed because of the LIERS, CROOKS, and THIEVES at Stockton wheel. Those are new wheels that were supposed to be custom back spaced to clear the brake kit. Well after waiting months and months for the wheels…. they didn’t clear the caliper. The only way I could use them is to use 1/4 inch spacers. Needed longer studs and had to go to a larger diameter. It was a total nightmare dealing with them. They refused to make the order right and straight up lied. I ordered the longer studs from my local CARQUEST auto parts. I don’t recall the brand. I took the old stud with me so they could match the shoulder diameter and length. the red wheels and black wheels are 15" this thread talks about extended lug nuts. May work for you Good luck Thanks for responding and wow that sounds really (bad) on their part i have changed studs out before and there plenty of naps local to me ill do the same thing pull a stud and take it in for comparreson or i could even hit up Randys Ring and Pinion im sure hes not to far from me
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I put 235/75/15 on my suburban,I like them.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | I take it those are 235/75-15s in that photo in your signature? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | 215/75R15 235/75R15 First pic truck has lowering springs Second pic stock springs. the 215 are about 1 1/2" shorter in diameter the 235 are almost 29" diameter, pretty close to stock. Good Luck If anybody has a set of wide white wall RADIAL tires like these and wants to sell them let me know please thanks 215/75R15
