| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I see taper bearing kits listed all over for the 1/2 tons but none for a 3/4 ton. Will the taper bearings from a newer 3/4 ton truck fit the 1948 3/4 ton?
Thanks | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Apparently there are none that will work without machine work. I remember someone posted on here that they had to turn down the spindle to make a tapered roller bearing from a Dodge, I think, fit. You could try a search of these forums and see that it has been discussed many times before. Sorry I am no help. Good luck.
Professional Novice
