4 members (Shade Baby, 1955 1 Series, 55shaker, Wally / Montana), 119 guests, and 4 robots.
Topics128,139
Posts1,056,448
Members48,441
#693516 11/09/2010 11:55 PM
I see taper bearing kits listed all over for the 1/2 tons but none for a 3/4 ton. Will the taper bearings from a newer 3/4 ton truck fit the 1948 3/4 ton?
Apparently there are none that will work without machine work. I remember someone posted on here that they had to turn down the spindle to make a tapered roller bearing from a Dodge, I think, fit. You could try a search of these forums and see that it has been discussed many times before.
Sorry I am no help. Good luck.
Professional Novice
