| | | Forums66 Topics128,056 Posts1,055,804 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | i recently bautgh this truck i dont know what model it his the tag in the door say model 9314 gmc the hood is gmc the grill 9310 ,the fender is apache 32 ,fleetside box,tailgate and the dash is gmc now for the engine block says gmc 283 with pontic valve cover .....can someone help me ! | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I'd say it's 90% GMC, with Chevy fender badging.... | | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | ok so what about the grill | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the shop beausejour, some pics in the DITY or Welcome forums would get you some info/opinions on your new toy - the model is indicated by the vin, it's a [93]1/2T [1]short [4]pickup
what about the grill? sounds like it's a GMC grill - the number on it is the series [short half ton], not the model, the "4" indicates pickup, there's also a 9311, and 9315 the same grill would have been used on - as Dave says, you have a GMC someone added Chev fender emblems to sometime in the past 50 years - also, the Pontiac engine was the one used in Canuck GMC's, don't lose those valve covers, they're hens teeth
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy beausejour, welcome, the model number you listed is for a GMC 1/2 ton pickup 114" wheelbase, 5000 lb. g.v.w., if it came with a V8 from the factory it would have been a Chevrolet 283, American GMCs came with Pontiac V8s from the factory up to series 500. Canadian Pontiac cars were also Chevrolet powered, so someone may have swapped in a "Canadian Pontiac" [Chevrolet] V8 at some point. I have a Chevrolet 283 in my shop that has valve covers on it which say Pontiac. Somewhere along the line someone has put Chevrolet fender spears on your truck, if they haven't swapped the entire fender. It can be a bit confusing the differences between Canadian and American models, I hope this explains some of what may have happened. | | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | tanks guy thats what i thaug about the fenders so is that the write grill and series is it | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy beausejour, if your grill has a 9310 identification in it, then it is a GMC grill, hope that helps | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | look at my pic, or at any '58-'59 pics in the Gallery for a GMC vs Chevy grille.... | | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | ok so i notice to that behind the park light theres hole in the grill but not in my truck to bolt it down | | | | | Joined: Mar 2012 Posts: 6 New Guy | | New Guy Joined: Mar 2012 Posts: 6 | 9315 model means panel cause i have the napco panel complete from end to end
