| | | Forums66 Topics128,186 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I am planning on converting my 49 suburban to an auto trans was looking for an auto column that will cool period correct in my truck found a guy on craigslist who has a powerglide column out of a 51 chevy car complete with wheeland linkage for pretty cheap im wondering if it will work in my truck or would it take to much fab work and is there a better column to look for to do this swap i dont care if its a tilt or not but not opposed to puttting a tilt in it if its cheap and easy enough Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | assuming the steering boxes will be different, one workable possibility is to use the car column jacket on the truck box/shaft if the car mast jacket is removeable
Bill | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Anyone else thought or seen this done?
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i use a powerglide shifter 1954 car on the stock column i have a 54 powerglide trans for sale | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | i know people who have used 49-54 car front ends/steering colums on burbs to eliminate the solid axle and they all have had to notch the frame rail to clear the steering gear box.
but i havent seen anyone use just the column | | |
