2 members (Peggy M, UtahYork), 62 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
#692388 11/05/2010 11:24 PM
I need somone with a 235 power glide(full pressure) engine to meassure the dip stick from the stop cup to the end,I have two of them and am not sure of the right one, also how many qt's of oil for a oil change the shop manual just says to fill to line ,that would be OK if I knew the right stick.I'm thinking that the oil pan is different for the car engine.
Pete
Pete52 #692394 11/05/2010 11:41 PM
Riding in the Passing Lane
They all hold 5 Qt's in the pan. Drain it & measure it & then check the dipstick.
1972 Chevy c10 Cheyenne Super
Pete52 #692396 11/05/2010 11:46 PM
Hi Pete,
The total length of the dipstick from my '55 powerglide 235 is 22 1/4 inches.Thats from the tip to the finger hole. The distance to the "full line" from the tip is 2" the distance to the add line from the tip is 1-1/4". Hope that helps.
50' chevy 3100 shortbed
jhannigan #692403 11/06/2010 12:00 AM
Thanks John , could You messure from the stop cup to the full mark .
Pete
jhannigan #692406 11/06/2010 12:09 AM
Pete,I just measured my 1956 235 powerglide dipstick.From the stop cup to the end is 15 9/16" long.Here are some photos of it.
15 9/16" long
Tim
1951 3100 Chevrolet
bowtietim #692518 11/06/2010 12:26 PM
Thanks,Tim I got the same one in My engine ,flat steel,Denny has round stock ones in His 235 and 216 are the same ,both truck engines I guess.
Thanks,John and WR
Tim hows the truck going?find Your seats ?
Pete
Pete52 #692606 11/06/2010 8:16 PM
Both of mine are truck engines for sure and I'm 99.9% these are the original parts to those original engines since I can follow the history of both back to when they were delivered. The truck and car must be different, but can't understand why they would be. A bit more research turned up this:
According to the 1929-1954 parts book:
All the specs are the same as the 1929-1957 parts book as follows.
According to the 1929 –1957 parts book:
47-55 COMM., UTIL., 1st Ser. (exc. D-D, COE),
49-54 PASS.,
53-55 CORV. 6 cyl…………………………………………….. (15 3/32 under washer)………….3701556
55-57 PASS. 6 cyl.,
55-57 COMM., UTIL. (6 cyl.)(2nd Ser.)(exc.D-D) (15 7/16” under washer)………….3710349
47-57 COMM., UTIL., (6 cyl.)(exc.D-D, COE),
49-57 PASS., CORV. (6 cyl.)………………………………..Tube (8 7/64” O.L.)………………3705397*
*NOTE: On jobs prior to 1955 cut to 6 ¾”.
Off subject for Peter Rabbit;
Remember this discussion Pete???
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0190.htm
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #692644 11/06/2010 11:21 PM
I'm wiggling My nose,Denny ,Thanks What are friends for but to help doing things that I find hard to do.
Pete
Pete52 #692672 11/07/2010 1:44 AM
Dip stick info, for all 6 cyl.
showing measurements to full and add line.
from the 1929-1959 parts catalog.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=656934
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #692738 11/07/2010 12:53 PM
Thanks,Tom
Pete
Pete52 #692841 11/07/2010 8:05 PM
Nevermind, I thought you were talking to me. grin
