1 members (NJC), 86 guests, and 1 robot.
Topics128,050
Posts1,055,643
#692134 11/05/2010 2:19 AM
I am having problems with my Carter W1 (574S) carb flooding out at times. I opened it up to clean and replace the accelerator pump and now it occasionally floods out. Gas will come up out of the accelerator plunger shaft hole on top of the bowl. I did not disturb the bowl setting. I am wondering if maybe the float needle seat valve could be sticking? Anyway I have been looking for the bowl setting and find that there is a number of settings used. I have the 235 in my 1-1/2 ton.
Any help would be really appreciated.
T,
I don't know the setting but if it worked before and the setting wasn't changed I'd leave it at that.
I'd also look for some crud that may have gotten in the needle seat that might be preventing it from shutting the fuel off, cause from what your saying the bowl is filling up and coming out the plunger shaft.
Is the float stuck.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
