4 members (3B, jmoore, TUTS 59, David Bush), 88 guests, and 1 robot.
Topics128,214
Posts1,057,488
Members48,473
So I'm considering using '55-'59 16" wheels on my '50 1/2-ton. They seem to be more readily available, and they're 6" from lip to lip instead of 5.25", which seems like maybe it will ride a little more solid. (When I called Patrick and suggested I was looking for old wheels, he said "Why! I wouldn't wish those wheels on anybody!" dang) Any thoughts on this switch? Do I need to worry about losing hub caps considering I'll have three clips instead of six? The hub caps fit okay, I've already checked, but does anyone have any experience using the old dog dish caps with the three clip wheels? Are they secure enough? They seem to be so.
Cheers,
Nick
they'll work fine and you'll have a better tire selection with the wider rim - I've used earlier caps on the 3 clip TF rims no problem, but if you're worried [GM wasn't!] the later wheels still have the 6 holes and you can get clips from the vendors to add on wink
Bill,
Great - thanks for your input. What does TF stand for?
Cheers,
nick
...oh, Task Force... of course, duh.
