1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | The passenger side window in my ’53 3600 is difficult to roll down for the last 5 or six inches. It wants to go further down in the back than the front and tries to “cock” rearward. If I press down very firmly on the front part of the glass, I can crank it all the way down with a lot of effort and force. If I don’t press, it won’t go down. I don’t find anything in the shop manual about lubricating anything on the windows or their mechanisms. What is the cause of this and what is the solution? The driver’s side window is becoming harder to crank but doesn’t “cock” one way or the other. Any help or advice is appreciated. John
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | A '54 manual says to remove any interior door trim to gain acess to door moving parts. Just use a light white grease. But, I would also check to see if the glass is slipping out of the metal base the pane rides in.
Drew
| | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | How do I determine if the glass is out of the metal base? John | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | After you access behind any door panel, crank the window down and you should be able to see the bottom of the window. A tug on the glass will tell you if it's coming loose.
Drew
