2 members (NJC, baldeagle), 57 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#690733 10/31/2010 5:52 PM
Well it's time to paint the frame on my 1948 GMC 1/2 ton Panel. Truck will look stock but running gear is not. Truck came from factory Green and will stay Green. I,m thing about using a satan black on frame and engine compartment minus firewall. is there a better choice ?
Thanks Dave
stoveboltfreak #691074 11/01/2010 10:47 PM
Sounds good to me even though I pained my frame gloss black.
I used Rustolium Satin Black for some things like inner fenders and it looks real good. I also used Rustolium Gloss Black for the frame but if I had it to do over, I'd use a 2K Urethane. It's thicker and harder... I've used it for my running boards, pedal rods and some other odds and it looks super.
Not sure if you can get satin black (AKA Underhood Black) in 2K but I'd look into it if I were you.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #691115 11/02/2010 12:59 AM
Thanks for the imput. I keep thing about going with a gloss black, but I,d send what little time I don't have trying to keep it nice and shiney. and that the only reason for using satan black. I,ll try to find a two part for the hardness.
Thanks Dave
I used rustolium Satin on the wishbones of my model A - the wishbone is directly under the carb wich always leaks and have not seen any wear issues with the paint.
....David
54barnfind #692018 11/04/2010 7:17 PM
Originally I used EASTWOOD Chassis Black diluted per directions to apply with a commercial gun. But,they have it in aerosol cans too. They also have newer, better choices now too. It's more expensive than your local hardware store, but it relly covered well and has held up very well. It also touches up easily when needed.
Drew
