3 members (Guitplayer, baldeagle, MickeyP), 104 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#691758 11/04/2010 1:50 AM
The passenger side window in my ’53 3600 is difficult to roll down for the last 5 or six inches. It wants to go further down in the back than the front and tries to “cock” rearward. If I press down very firmly on the front part of the glass, I can crank it all the way down with a lot of effort and force. If I don’t press, it won’t go down. I don’t find anything in the shop manual about lubricating anything on the windows or their mechanisms. What is the cause of this and what is the solution?
The driver’s side window is becoming harder to crank but doesn’t “cock” one way or the other. Any help or advice is appreciated.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
A '54 manual says to remove any interior door trim to gain acess to door moving parts. Just use a light white grease. But, I would also check to see if the glass is slipping out of the metal base the pane rides in.
Drew
How do I determine if the glass is out of the metal base?
After you access behind any door panel, crank the window down and you should be able to see the bottom of the window. A tug on the glass will tell you if it's coming loose.
Drew
Moderated by  ndkid275, Phak1
