1 members (Ponchogl), 163 guests, and 3 robots.
Topics128,101
Posts1,056,182
Members48,436
Apprentice
Apprentice
Can some or one of the "experienced" tell me if the Stainless Steel windshield trim can be in stalled with the windshield already mounted with a new gasket?
Jon
Nashville, TN
Im not "experienced"
Done it one time
check out this thread
https://www.stovebolt.com/ubbthread...;Main=96618&Number=667666#Post667666
it wont go in if the windshield is installed on the truck
Maybe an experienced person can post up and confirm ,
this was on a two piece windshiled. may not apply to your truck
good luck
Jon, sorry to tell you,but the trim should be installed in the rubber before the whole assembly is fitted.
I've heard tales of woe concerning this,and it is nigh on impossible to do after the windshield is in.
You run the risk of tearing up your new rubber,bending the trims and not to mention the possibility of damaging the surrounding paint etc.
I've just recently rectified a customer of mines Jensen for the very same reason.
I had to remove the windshield and start over again.
More pix on Flickr.
It would be impossible to install the 54/55 stainless trim without damage (no matter what combination of swear words and other invectives are used).
It's hard enough trying to install them correctly with the windshield out.
Most likely you are aware that the windshield rubber seal is different when using the stainless trim?
Not an easy job, I tried rubber from three sources before I got one I could work with, the ones made in Thailand didn't work for me at all.
I put the rubber on the windshield, held in place with tape, then fitted the shainless into the rubber, not easy, held in place with tape.
Now inserted the rope wetted with watered down liquid detergent. Then sit the assembly onto the bottom lip of the cab. Used the method in the maintenance manual, got to the top edge with two helpers, couldn't get the top to snap in. Next day applied even pressure across the whole top edge of the windshield assembly, it popped in, Never had to bang on it with my hand. I looked at in disbelief, done.
I’ve heard that rubber from Steele is the best, the one I used was from CounterParts.
Congratulations. Thanks for the report.
I gave up on the last two that I tried (using Steele and others). I will not give up on the next two that I am now working on.
Even pressure across the top: with the top of the windshield a little less that 8ft from my garage wall, using three 1x3 by 8ft cedar (very flexible) I spaced them evenly across the top of the windshield, with the opposite end against the wall, one by one I increased the bow in the boards by moving the wall-end lower and lower, then manipulated the rubber seal into place. I know it sounds crazy but it worked. Don
You're right, that does sound crazy. But it's great that it worked!
