6 members (Stan 58, 46 Texaco, RoadsScholar, Otto Skorzeny, Peggy M, 1 invisible), 127 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#691893 11/04/2010 11:24 AM
I needed a new fuel pump for my 41 1.5 ton chevy, so I found a fuel/vac pump. How do I hook up the vacuum side of the pump, where do the vac lines go? It is a vac pump to help prevent the wipers from slowing, but I'm not sure how to attach the lines.
Here are a couple of pictures 216 that we plumbed in on a friends 1950, 3100 with vacuum wipers.
http://www.pbase.com/dennygraham/image/121027791/original
http://www.pbase.com/dennygraham/image/121027822/original
The manifold line is run into the side where the vacuum line used to be. You can see that in this picture: http://www.pbase.com/dennygraham/image/121095639/large The flex hose from the wipers to the hard line is visible behind the carb also.
Here is a link to all the pictures of the plumbing: http://www.pbase.com/dennygraham/larrys_1950_3100&page=all
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thank you Denny, its 6:55a.m. here in CT and you just made my day!
Rob
Always glad to help out a brother welder. Believe me, I know how crappy the day can be after standing over a hot puddle all day long for many years.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
