9 members (Gdads51, 52Carl, fonz8261, greenie-reddy, 2-Ton, Forty9, RoadsScholar, mk72, 1 invisible), 138 guests, and 1 robot.
Topics128,125
Posts1,056,343
Members48,441
Drivers door has a mirror and I would like to install one on the passenger side.
There are no holes or anything there.
Are there pre-installed threaded fittings under the door skin that need to be located or do they have to be installed ?
1956 3200
Year and make and model of truck?
always useful to indicate a year, different series can be totally different ... I believe you've got a 56? should be able to see the mirror mount reinforcing plate looking inside with the door trim panel off
Thanks Bill- you are correct,it's a 1956 3200
I have a 66 gmc, does it have the mirror bracket under the passenger door skin also, Kieth
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
