0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Drivers door has a mirror and I would like to install one on the passenger side.
There are no holes or anything there.
Are there pre-installed threaded fittings under the door skin that need to be located or do they have to be installed ?
1956 3200
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Year and make and model of truck?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | always useful to indicate a year, different series can be totally different ... I believe you've got a 56? should be able to see the mirror mount reinforcing plate looking inside with the door trim panel off
Bill | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Thanks Bill- you are correct,it's a 1956 3200 | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I have a 66 gmc, does it have the mirror bracket under the passenger door skin also, Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
