5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
#691698 11/03/2010 10:25 PM
After alot of heat applied to axle flange to get old studs out, what is the best way to install new studs? Tried to pull in a couple with a lug nut and washer, but the nut stripped out as the stud gripped the hole!!!
3B Offline
Hy bowtiefan, you should install the new studs with a press, pulling the studs into place with nuts puts a lot of stress on them.
I recently installed new studs and new front drums on my '50 3100. I started the studs with a soft hammer on the hubs to get them properly seated in the grooves, then mounted the hub to the drum and used new lug nuts in reverse, that is flat side to the drum, and cross alternated tightening the studs and drawing them in the rest of the way. It was necessary to hold the drum in a vice and use an extended socket bar for leverage. I never tightened each lug nut more than one complete turn at a time while alternating. It took a little time, but I had no trouble getting them in. I also replaced the hub gaskets too. If you have access to a press, that would make it an easier job.
Drew
I use this tool to install studs at work. Has much more thread contact on the stud that using just the nut, which eliminates damage to the threads.
Bill Burmeister
Boetiefan; Drew is on .Now this is from the AD times.I would put the studs in the freezer for a few hour's.Then start the studs in with a soft hammer.Reverse the nut an use a air impact to finish the job.I also used this on ball joints.Old tricks in the good old days.When a truck was a truck.......
dan-pa
