4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#69166 11/25/2006 7:36 AM
I have a 63 that I switched from manual to the factory brake booster setup with a 72 truck dual MC and proportioning valve, all new. I,ve got good pedal but they feel like manual brakes. I've got good vacuum from the 350. What am I missing? In one of the forums I think I read that the pushrod from the pedal can be adjusted, could that be the answer? I'm open for any ideas. Thanks
#69167 11/25/2006 4:41 PM
3B Offline
Hy Fortynine5, here's one way to test your booster, with the engine off pump your brake pedal a few times, now put your foot on the pedal and hold it down, now start the engine, if the booster is working the pedal should go closer to the floor when you start the engine, hope that helps.
#69168 11/25/2006 10:33 PM
Riding in the Passing Lane
I had the same problem with a 63 I had. I redrilled the brackets that the pushrod from the pedal goes to to move it closer to the pivot point. Helped a lot. You pushrod should be adjusted to have a small amount of play before pushing in the booster or master cyl.
1972 Chevy c10 Cheyenne Super
